Voice Gateway Module offlline.
Hello;
I am facing a slight problem here. Hope somebody can help me out on this one. Following is the output of " sh module" of a 4507 switch.
#sh mod
Chassis Type : WS-C4507R
Power consumed by backplane : 40 Watts
Mod Ports Card Type Model Serial No.
1 2 Supervisor IV 1000BaseX (GBIC) WS-X4515 JAE0802100H
2 2 Supervisor IV 1000BaseX (GBIC) WS-X4515 JAB064705B2
3 1 Voice Gateway WS-X4604-GWY JAB044604QX
4 48 10/100/1000BaseT (RJ45) WS-X4448-GB-RJ45 JAB0803061Z
5 48 10/100/1000BaseT (RJ45)V, Cisco/IEEE WS-X4548-GB-RJ45V JAE09065KNJ
6 48 10/100BaseTX (RJ45)V WS-X4148-RJ45V JAB08030CVC
7 48 10/100BaseTX (RJ45)V WS-X4148-RJ45V JAB08030CY0
M MAC addresses Hw Fw Sw Status
1 000e.d71e.7c00 to 000e.d71e.7c01 3.1 12.1(20r)EW2 12.2(25)EWA Ok
2 000e.d71e.7c02 to 000e.d71e.7c03 1.4 12.1(20r)EW2 12.2(25)EWA, Ok
3 0002.4bbc.db1e to 0002.4bbc.db1e 1.8 Offline
4 000f.2318.8580 to 000f.2318.85af 1.1 Ok
5 0013.19f5.3b20 to 0013.19f5.3b4f 2.2 Ok
6 000f.2387.2ad0 to 000f.2387.2aff 2.7 Ok
7 000f.2387.1a50 to 000f.2387.1a7f 2.7 Ok
--More--
Mod Redundancy role Redundancy mode Redundancy status
1 Active Supervisor SSO Active
2 Standby Supervisor SSO Standby hot
As we can see from the above mentioned output, the gateway module is shown as offline.
My query to you is whether this is a case of hardware being down or it because some kind of software configuration change has been done on the same?
Hoping to get a quick reply.
Thank you.
Kiran Cherian.
Re: Voice Gateway Module offlline.
hi
Have you tried reinstalling the card in the slot ?
If you have another switch can you insert on that and check wehther you are getting it online ??
if you still dont have any luck after this better get in touch with TAC to resolve the same..
regds
First make sure that you have the minimum IOS on the 4604 for use with a Native IOS Sup Module, I believe it is 12.2(13)T or later. Second, I had to reboot the 4500 before it would come online, the 4604 was booting up and everything but would not come online until the reboot.
Good luck.
102
