Voice over Frame Relay Quality of service
Hi, my name is Raymond. I have a few questions regarding vofr qos. Recently I had implemented vofr in one of my customer. Here is a brief description about it. One HQ with two branches, each using Cisco 3640. The router in HQ is connected to Lucent PBX with NM-HDV-1E1-30 modul. Each of the branches have 12 FXO ports. The backhaul bandwidth in use in HQ are 512K with 256K CIR for voice and 128K with 64K CIR for data, split into two for each branch. Currently I am using subinterfaces to split the voice and data. Because the bandwidth in each branch still 128K each then I am only using 10 FXO ports. I will also attach each configuration. But my customer is still complaining about the quality of voice and the data itself when there are 20 concurrent calls. It is a call center so the vofr must be able to support 20-24 concurrent calls. Kindly give me an advise about my configuration. tx
Rgrds
Ray
This is the HQ config :
sh run
Building configuration...
Current configuration : 6656 bytes
version 12.2
no parser cache
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
logging rate-limit console 10 except errors
voice-card 2
ip subnet-zero
no ip domain-lookup
no ip dhcp-client network-discovery
isdn switch-type basic-5ess
call rsvp-sync
voice service vofr
controller E1 2/0
framing NO-CRC4
ds0-group 0 timeslots 1-6 type e&m-melcas-immed
ds0-group 1 timeslots 7-12 type e&m-melcas-immed
ds0-group 2 timeslots 13-15,17-19 type e&m-melcas-immed
ds0-group 3 timeslots 20-25 type e&m-melcas-immed
interface FastEthernet1/0
ip address 3.241.28.6 255.255.252.0
speed auto
half-duplex
no cdp enable
no mop enabled
interface Serial1/0
mtu 200
no ip address
encapsulation frame-relay
no ip mroute-cache
frame-relay traffic-shaping
frame-relay ip rtp header-compression
interface Serial1/0.1 point-to-point
description 'FR to BDG'
bandwidth 128
ip address 3.244.159.241 255.255.255.252
no cdp enable
frame-relay interface-dlci 21
class VOIPovFR
vofr cisco
interface Serial1/0.2 point-to-point
description 'FR to SBY'
bandwidth 128
ip address 3.241.32.5 255.255.255.252
no cdp enable
frame-relay interface-dlci 20
class VOIPovFR
vofr cisco
interface Serial1/0.3 point-to-point
description 'f/r data to surabaya'
bandwidth 32
ip address 3.244.159.201 255.255.255.252
no cdp enable
frame-relay interface-dlci 22
class Data
interface Serial1/0.4 point-to-point
description 'f/r data to bandung'
bandwidth 32
ip address 3.244.159.197 255.255.255.252
no cdp enable
frame-relay interface-dlci 23
class Data
interface Serial1/1
no ip address
shutdown
clockrate 2000000
interface Serial1/2
no ip address
shutdown
clockrate 2000000
interface Serial1/3
no ip address
shutdown
clockrate 2000000
interface BRI3/0
description *** ISDN Back Up Link from Jakarta to Surabaya ***
bandwidth 128
ip unnumbered Loopback2
encapsulation ppp
ip tcp header-compression iphc-format
no ip mroute-cache
dialer idle-timeout 300
dialer map ip 3.140.106.1 name gdn_hsg_singapore1 broadcast
dialer load-threshold 5 either
dialer-group 10
fair-queue 64 16 0
no cdp enable
ppp authentication chap
ppp multilink
ppp multilink fragment-delay 20
ppp multilink interleave
ip rtp header-compression iphc-format
ip rtp priority 16384 16383 40
interface BRI3/1
description *** ISDN Back Up Link from Jakarta to Bandung ***
bandwidth 128
ip unnumbered Loopback1
encapsulation ppp
no ip mroute-cache
dialer map ip 3.244.159.242 name gecgcfidrtrbdg1 0224250124
dialer-group 10
fair-queue 64 16 0
no cdp enable
ppp multilink
interface BRI3/2
no ip address
shutdown
interface BRI3/3
no ip address
shutdown
router eigrp 251
network 3.0.0.0
no auto-summary
no eigrp log-neighbor-changes
ip classless
ip route 0.0.0.0 0.0.0.0 3.241.28.1
ip route 3.241.36.0 255.255.252.0 Serial1/0.3
ip route 3.244.152.0 255.255.255.0 Serial1/0.4
no ip http server
map-class frame-relay VOIPovFR
no frame-relay adaptive-shaping
frame-relay cir 128000
frame-relay bc 1000
frame-relay be 0
frame-relay mincir 128000
frame-relay fair-queue
frame-relay voice bandwidth 128000
frame-relay fragment 160
map-class frame-relay Data
frame-relay cir 32000
frame-relay mincir 32000
access-list 1 deny 0.0.0.0
access-list 1 deny 3.0.0.0
access-list 1 permit any
access-list 199 deny ip host 255.255.255.255 any
access-list 199 permit ip any any
dialer-list 10 protocol ip list 199
snmp-server community gecgcfid RO
snmp-server enable traps isdn call-information
snmp-server enable traps isdn layer2
snmp-server enable traps isdn chan-not-avail
snmp-server host 3.241.28.82 inform version 2c gecgcfid
snmp-server host 3.241.28.82 version 2c gecgcfid
voice-port 2/0:0
input gain 14
output attenuation 14
voice-port 2/0:1
input gain 14
voice-port 2/0:2
input gain 14
voice-port 2/0:3
input gain 14
dial-peer cor custom
dial-peer voice 1 pots
destination-pattern 225....
port 2/0:0
dial-peer voice 2 pots
preference 1
port 2/0:0
dial-peer voice 3 pots
preference 2
port 2/0:0
dial-peer voice 4 pots
preference 3
port 2/0:0
dial-peer voice 5 pots
preference 4
port 2/0:0
dial-peer voice 6 pots
preference 5
port 2/0:0
dial-peer voice 7 pots
destination-pattern 223....
port 2/0:1
dial-peer voice 8 pots
preference 1
port 2/0:1
dial-peer voice 9 pots
preference 2
port 2/0:1
dial-peer voice 10 pots
preference 3
port 2/0:1
dial-peer voice 11 pots
preference 4
port 2/0:1
dial-peer voice 12 pots
preference 5
port 2/0:1
dial-peer voice 13 pots
destination-pattern 315....
port 2/0:2
dial-peer voice 14 pots
preference 1
port 2/0:2
dial-peer voice 15 pots
preference 2
port 2/0:2
dial-peer voice 16 pots
preference 3
port 2/0:2
dial-peer voice 17 pots
preference 4
port 2/0:2
dial-peer voice 18 pots
preference 5
port 2/0:2
dial-peer voice 19 pots
destination-pattern 313....
port 2/0:3
dial-peer voice 20 pots
preference 1
port 2/0:3
dial-peer voice 21 pots
preference 1
port 2/0:3
dial-peer voice 22 pots
preference 2
port 2/0:3
dial-peer voice 23 pots
preference 3
port 2/0:3
dial-peer voice 24 pots
preference 4
port 2/0:3
line con 0
line aux 0
line vty 0 4
login
end
this is the 1st branch config :
sh run
Current configuration : 3234 bytes
version 12.2
no parser cache
ip subnet-zero
no ip domain-lookup
call rsvp-sync
interface FastEthernet0/0
ip address 3.244.152.1 255.255.255.0
no ip mroute-cache
speed auto
half-duplex
no cdp enable
no mop enabled
interface Serial0/0
mtu 200
no ip address
no ip mroute-cache
interface Serial0/0.1 point-to-point
bandwidth 128
ip address 3.244.159.242 255.255.255.252
no ip mroute-cache
no cdp enable
class VOIPovFRtoJKT
vofr cisco
interface Serial0/0.2 point-to-point
bandwidth 32
ip address 3.244.159.198 255.255.255.252
no ip mroute-cache
no cdp enable
class Jktdata
interface BRI0/0
encapsulation ppp
no ip mroute-cache
shutdown
fair-queue
no cdp enable
ppp multilink
interface Serial0/1
no ip address
no ip mroute-cache
shutdown
clockrate 2000000
router eigrp 251
network 3.0.0.0
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/0.2
no ip http server
ip pim bidir-enable
map-class frame-relay VOIPovFRtoJKT
frame-relay bc 1000
frame-relay be 0
map-class frame-relay Jktdata
snmp-server location Bandung
snmp-server contact Ruliyanto
snmp-server host 3.241.28.82 gecgcfid
voice-port 1/0/0
connection plar 2255225
voice-port 1/0/1
voice-port 1/1/0
voice-port 1/1/1
voice-port 2/0/0
voice-port 2/0/1
voice-port 2/1/0
connection plar 2233663
voice-port 2/1/1
voice-port 3/0/0
voice-port 3/0/1
voice-port 3/1/0
voice-port 3/1/1
dial-peer cor list name
dial-peer voice 3 vofr
session target Serial0/0 21
dtmf-relay
dial-peer voice 4 vofr
dtmf-relay
line con 0
line aux 0
line vty 0 4
login
end
This is the 2nd branch config :
sh run
Current configuration : 3310 bytes
version 12.2
no parser cache
ip subnet-zero
no ip domain-lookup
call rsvp-sync
ip address 3.241.36.1 255.255.252.0
no ip mroute-cache
speed auto
half-duplex
no cdp enable
no mop enabled
interface Serial0/0
mtu 200
no ip address
no ip mroute-cache
bandwidth 128
ip address 3.241.32.6 255.255.255.252
no ip mroute-cache
no cdp enable
class VOIPovFRtoJKT
vofr cisco
bandwidth 32
ip address 3.244.159.202 255.255.255.252
no ip mroute-cache
no cdp enable
class Sbydata
interface BRI0/0
encapsulation ppp
no ip mroute-cache
fair-queue
no cdp enable
ppp multilink
interface Serial0/1
no ip address
shutdown
clockrate 2000000
router eigrp 251
network 3.0.0.0
no auto-summary
ip classless
no ip http server
frame-relay bc 1000
frame-relay be 0
map-class frame-relay Sbydata
voice-port 1/0/0
connection plar 3155225
voice-port 1/0/1
voice-port 1/1/0
voice-port 1/1/1
voice-port 2/0/0
voice-port 2/0/1
voice-port 2/1/0
connection plar 3133663
voice-port 2/1/1
voice-port 3/0/0
voice-port 3/0/1
voice-port 3/1/0
voice-port 3/1/1
session target Serial0/0 20
dtmf-relay
dtmf-relay
line con 0
line aux 0
line vty 0 4
login
end
Re: Voice over Frame Relay Quality of service
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
Have you worked this out yet? In looking at your configs, I'd suggest a few things -
Make sure you shape the data PVCs as well as the voice PVCs. Currently, traffic on your data PVCs could delay the transmission of voice packets. This is probably the issue that is biting you.
I typically use the following values for the frame-relay map-class
1) cir = cir of PVC
2) mincir = cir
3) be = 0
4) bc = cir/100 (this gives you a 10ms Tc)
5) frag = appropriate value for lowest access
speed on either end of PVC
It looks like you have a 512K FT1 with 4 PVCs (2 @ 128K CIR and 2 @ 32K CIR) at your HQ, and a ???K FT1 with 2 PVCs (128K CIR and 32K CIR) at each branch. Is this right? The port speed at the branch sites is probably 256K then. This would allow you to increase the fragment size to 320 bytes.
Good luck!
- Paul
Hi Ray
Try
frame-relay ip rtp priority 16384 16383 bw
instead of frame-relay voice bandwidth
and there is no need to configure mtu 200,
you have already done frame relay fragmentaion
Juergen
Ray is attempting VoFR, not VoIP. He'll need to use layer 2 QoS methods (FRF.11 and FRF.12) rather than layer 3 methods (RTP priority, LLQ, MQC, etc).
I agree that the 'mtu 200' statement should be removed. Since he's using frame-relay fragmentation there is no need for this.
- Paul
Paul and Juergen thanks for your suggestion.
Paul regarding your suggestion I have a few question. Hope it doesn't botter you and you don't mind to answer it.
You said that I need to shape both data and voice PVC. Does it mean I gotta made separate 'frame-relay map-class' for the data PVC? If currently the data PVC bandwidth only 32kb, then what should the 'frame-relay fragment' be? Right now I already made those separate but without add the 'frame-relay be, bc, fragment and fair-queue' on 'frame-relay map-class' for data PVC. Does it matter??
When there are only 5 concurrent calls then all the 5 calls are fine. The problem arise when there are more then 5 calls. All the conversation then would suffer as if 'there isn't enough bandwidth' (with 128kb using the standard ios codec, I should have 10 calls simultaneously right?)
Just as you said, I think the data traffic (even if they are separate by different PVC) cause this. If I physically separate the serial for voice and data would it be helpful?
Anyway tx a lot.
Rgrds,
Ray
Ray,
Yes, you should take the map-class you have for data on each router and enable FRF.12 (via the frame-relay fragment statement). Even though voice and data are on seperate PVCs, they still travel across the same serial interface and are intermingled.
The fragment size is dependant on the port speed (ie - how quickly will the frame be serialized). Whatever your CIR is, Cisco recommends 160 bytes as a starting point for a 128K access rate, 320 bytes for a 256K access rate, etc... so that no packet takes longer than 10ms to serialize at each interface. Determine the access rate at each end of the PVC and use the slower rate to determine your fragment size for this PVC.
Yes, if all that was running across the serial interface was a PVC hadling FRF.11 voice you could avoid QoS issues involving data. However, you are back to having a seperate network for voice and data. You lose the advantage of a multiservice network.
170
