Voice-over-IP Gateway white paper
cechambers
This is intended as more of a suggestion than a discussion.
In white paper for "Voice-Over-IP Gateway", the specific network modules associated with the Cat6000/Cat4000 used for providing Voice gateways are listed, but for the Cisco 2600/3600, they are not specified. It would make that document much clearer and specific as the software/modules evolve.
ciscomoderator
Community Manager
Community Manager
Hello Charles,
I forwarded your suggestion on to our Cisco.com TAC support team and they suggested you review this URL: http://www.cisco.com/warp/public/788/products/voice_comp_matrix.html
In the future, note there is a "Feedback" button on the bottom of each document on the TAC website you can use to make such suggestions. Providing this feedback through their interface routes your suggestion directly to the engineering team in charge of that particular document automatically.
They would like you to fill one out for the particular document you were referring to so they can get it updated.
Thank you for posting to our forum.
