Community Member
voice prompts to IVR applications
I need to test some IVR functions of Cisco gateways (cisco 2600 with mn-hdv-2E1). Where could I download voice prompts ?? Could Someone give me the link to download it??
thanks in advance,
Luiz
Silver
Re: voice prompts to IVR applications
Guess, you can create voice prompts on your own and store it for use of IVR. May be you can use Cisco VCO/4K Open Programmable switches for this purpose. Using these, you can have a voice prompting system. For more details please refer to :
Cisco VCO/4K Open Programmable switches Overview
http://www.cisco.com/en/US/products/hw/switches/ps2246/products_configuration_guide_chapter09186a00800ea6c0
Community Member
Hi Ires,
Thanks for your reply, I've trying audio files made by my self, but the quality was so bad. I wander have professional prompts in somewhere of Cisco web site.
Anyway, thanks for your response.
Luiz
Silver
Check out here -
http://www.cisco.com/cgi-bin/tablebuild.pl/tclware
The prompts are bundled in the debitcard 2.000 application zip files - if you download the 3 meg file and unzip it you will find a whole lot of voice prompts.
You will need CCO software centre download access to get these files.
Community Member
Paul
Thank you very much for your information.That's exactilly what I've looking for ;)))
regards
Luiz
129
