Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
voice quality issue
I am having a Cisco 7206 VXR running Version 12.2(15)T17.There is one 2 mb IPLC link that is connecting our India office to US office over which we run voip phones.I have nortel phones in our office and the call manager is in US.Now we face lots of voice quality issues.I have rectified the latency and loss issue over the IPLC ckt.Kindly check the configuration that I have done on the router and suggest if any configuration change needs to be done.
class-map QoS-voip
match access-group name QoS-voip
class-map QoS-data1
match access-group name QoS-data1
policy-map llq
class QoS-voip
priority 1024
class QoS-data1
bandwidth 256
class class-default
fair-queue
interface Serial1/0
description " IPLC link connected to US "
bandwidth 2048
ip address 10.252.x.x 255.255.x.x
service-policy output llq
ip access-list extended QoS-voip
permit ip 10.252.x.x 0.0.0.255 10.217.x.x 0.0.0.x
permit udp any 10.217.x.x 0.0.x.x range 5200 5263
permit tcp any 10.217.x.x 0.0.0.x range 5200 5263
permit udp any range 5200 5263 10.x.x.x 0.0.0.x
permit tcp any range 5200 5263 10.x.x.x 0.0.0.x
Blue
Re: voice quality issue
you should prioritze the voip signaling as well as the RTP streams.
from what i can tell, it looks as though this accessList accepts ip all protos. to 10.217.x.x. is this the voice vlan where call processors are? is there data on these networks as well?
if so, then it looks like all nonVoice data between 10.252 and 10.217 is given the voip bandwidth as well.
Concurr if you use MQC and use protocols (RTP) and give that voice and (RTCP) and make it next highest and then the other you probably will have a better setup.
class-map match-any VOICE
match protocol rtp
match dscp ef
class-map match-any VOICE_CTRL
match protocol rtcp
match dscp af31
class-map match-all default
then set your policy map from it.
140
