Community Member
Voice translation-rule - 15 rules max.
I need to create more 15 rules in a voice translation-rule but 15 is the maximum number. What can I do to creat more?
Thanks a lot...
Ced
Green
Re: Voice translation-rule - 15 rules max.
You may create multiple profiles and different rules. Is there any reason you need to use the same rule?
You can create more dial-peers also.
We have that limitation now:
A Maximum of 128 rules with 15 translation per rule.
An up to 1000 profiles.
Community Member
Thanks for your response...
Ok but how can I do?
I want to translate 30 incoming number.
I use for that "voice translation-rule" :
voice translation-rule 10
rule 1 /0001/ /4000/
rule 2 /0002/ /4213/
rule 3 /0003/ /4209/
rule 4 /0004/ /4113/
rule 5 /0005/ /4215/
rule 6 /0006/ /4217/
rule 7 /0007/ /4219/
rule 8 /0008/ /4222/
rule 9 /0009/ /4223/
rule 10 /0010/ /4224/
rule 11 /0011/ /4208/
rule 12 /0012/ /4207/
rule 13 /0013/ /4206/
rule 14 /0014/ /4216/
rule 15 /0015/ /4214/
voice translation-profile INCOMING
translate calling 101
translate called 100
dial-peer voice 100 pots
translation-profile incoming INCOMING
service mgcpapp
destination-pattern *0T
incoming called-number 0.
direct-inward-dial
port 0/1/0
forward-digits all
It's OK for 15 translation. But for my 30, what can I do?
Thanks a lot
Ced
Community Member
Hi !!
I've had the same issue and I solved it using TCL scripts and it works just fine.
Check on CCO and you'll find even some examples to download and use.
Hall of Fame Super Silver
You can create seperate incoming dial-peers with differnet profiles, such as:
voice translation-rule 11
voice translation-profile INCOMING_000
voice translation-profile INCOMING_001
translation-profile incoming INCOMING_000
incoming called-number 000.
direct-inward-dial
port 0/1/0
dial-peer voice 101 pots
translation-profile incoming INCOMING_001
incoming called-number 001.
direct-inward-dial
port 0/1/0
and so forth,
HTH,
Chris
Community Member
Hi Chris,
Well Done!!! It's OK with this solution
Thanks a lot
Best Regards
Ced
Excellent,
If you don't mind please rate all helpful posts!
Chris
2068
