VoIP advice
I got a 3661 route with only ONE FREE slot. Can somebody advice me on the type of network module and IOS I should buy If I want to use E&M or FXO for 4 telephone connections.
I want the setup to be like this
telephone<--->PABX <--------->3661<-------->1751V<--->telephone
We have got two branch office and want them to connect to the HQ and be part of the HQ PABX. There will be no PABX at the branch office(Later).
We use 1024Kbps lease line between the brach office's and the HQ
I believe I got enough memory. here is the show version of my 3661 router
sho ver
IOS (tm) 3600 Software (C3660-I-M), Version 12.2(5a), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Thu 04-Oct-01 22:21 by pwade
Image text-base: 0x600089C0, data-base: 0x60A60000
ROM: System Bootstrap, Version 12.0(6r)T, RELEASE SOFTWARE (fc1)
ITC-Central-1> uptime is 21 hours, 52 minutes
System returned to ROM by reload
System image file is "flash:c3660-i-mz.122-5a.bin"
cisco 3660 (R527x) processor (revision 1.0) with 83968K/14336K bytes of memory.
Processor board ID JAB0549801G
R527x CPU at 225Mhz, Implementation 40, Rev 10.0, 2048KB L2 Cache
Bridging software.
X.25 software, Version 3.0.0.
Basic Rate ISDN software, Version 1.1.
3660 Chassis type: ENTERPRISE
5 FastEthernet/IEEE 802.3 interface(s)
10 Serial network interface(s)
2 ISDN Basic Rate interface(s)
16 terminal line(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
40960K bytes of processor board System flash (Read/Write)
Hope someone helps
Re: VoIP advice
First you need an IP Plus feature set image in order for the IOS to recognize your voice hardware.
As for voice cards, I would suggest to use E&M cards. The parts are NM-2V the network module in which the VIC-2E/M cards (2, providing you 4 ports) reside.
You can use the VIC-2FXOs as well depending on if your PBX can do loop/ground signaling but in order to avoid the supervisory disconnect issues E&M is preferred.
I hope that helps.
Re: VoIP advice
How about the branch office. Will I use FXS card or FXO ?
Re: VoIP advice
At the branch office if you are going to use just analog phones directly attached to the router then you would use the FXS cards. You can not connect analog devices(phones/faxes) to the FXO port directly.
85
