07-12-2002 08:08 AM - edited 03-12-2019 07:53 PM
http://www.cisco.com/warp/public/788/signalling/fxo_disconnect.html#3
-- Note: Cisco Moderator edited above url to point to a publicly veiwable document in an effort to widen audience. --
Please see the above url case 3 :
I have a job involves ,2 7206 vxr are conneted via E1 and pabx on both ends,using the voip access now.
but the customer wishes to connect FE0 form 7206 to 1751v routers and connect to FXO -
OTHER END IS FXS.
COULD THIS WORK ?
regards
07-23-2002 08:37 PM
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you, or there is no public information available at this time. If you don't get a suitable response to your post, you may wish to review our resources online at http://www.cisco.com/go/solutions. You may also contact our product information line at 1-800-553-NETS or a Cisco Systems Engineer at your local Cisco office or reseller. To locate your local Cisco representative, visit http://www.cisco.com/warp/public/687/Directory.shtml
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
08-07-2002 06:51 AM
Hello -
The analog signalling is not end-to-end, so as long as you have an FXS device connected to the 1751 router's FXO port, this shouldn't be a problem. Keep in mind there are issues with answer supervision and supervisory disconnect with FXO ports, search CCO for more information on how to address those.
Clay
