Community Member
VoIP and E1 CAS3Bit Problem
Dear friends,
I have a problem in implementing a VoIP project, we have many E1 lines with CAS-3Bits signaling.
I want to find out how can I convert it to E1 CAS-R2 to connect it with my 3662 Access Routers or how can I do this with my AS-5300 VoIP gateway.
Is there any converter, signaling card or modules...?
Shafagh Zandi (CCNA, MCSE, MCP+I)
Re: VoIP and E1 CAS3Bit Problem
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you, or there is no public information available at this time. If you don't get a suitable response to your post, you may wish to review our resources at the online You may also contact our product information line at 1-800-553-NETS or a Cisco Systems Engineer at your local Cisco office or reseller. To locate your local Cisco representative, visit
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
Community Member
Check RAD's signaling coverter @
