Community Member
voip audio one way
I have Voip but audio work one way
Anonymous
N/A
Re: voip audio one way
1. check if you have IP routing enabled.
If you see "no ip routing " in your config, its probably not enabled. Please enable ip routing.
2. There might be a codec mis-match in one direction.
3. Check debug h225 ansi and see the source address sent as your h245 contact. See if this address is reachable by all host.
solution would be make sure all interface address are pingable from every voip router i.e loopbacks, ethernet , serial etc.
Community Member
Also, check this URL as it lists all possible causes of one-way audio:
http://www.cisco.com/warp/public/788/AVVID/fix_1way_voice.html
Hope this helps.
393
