Community Member
VoIP calls drop over EZVPN
Interesting issue. I have one of my remote users that ends up getting one way audio issues to shortly follow with a disconnect of the phone call. The VPN hardware is a 5505 ASA at the remote end and a ASA 5510 on the hub end configured via EZVPN. The IP phone register to a central call manager. The call gets placed and has two ways audio. After a minute or two the one way audio issue comes up and followed by the call disconnecting.
The tunnel stays up and does not effect other traffic. The link is barely being used and is a cable modem with about a 2 meg upload connection.
To add, I have about 30 other remote users set up this way working fine.
Is the issue with the service provider or are there some other config settings I can try on the remote end ASA?
Re: VoIP calls drop over EZVPN
can u post the ASA config (that has the problem)
as lon as u said u have other sites working then i think the main site is configured corectly
Community Member
Here you go:
sh run
: Saved
ASA Version 7.2(4)
hostname RemoteASA-15
domain-name abc.com
enable password xxx
passwd xxx
names
interface Vlan1
nameif inside
security-level 100
ip address 10.28.252.113 255.255.255.248
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
boot system disk0:/asa724-k8.bin
ftp mode passive
clock timezone CST -6
clock summer-time CDT recurring
dns server-group DefaultDNS
domain-name abc.com
pager lines 24
logging enable
logging timestamp
logging buffered debugging
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-523.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
timeout xlate 1:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
telnet 10.28.0.0 255.255.0.0 inside
telnet timeout 5
ssh 10.28.0.0 255.255.0.0 inside
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 5
console timeout 30
management-access inside
dhcpd auto_config outside
dhcpd option 150 ip 10.28.2.33
dhcpd address 10.28.252.114-10.28.252.118 inside
dhcpd enable inside
vpnclient server 70.140.290.117
vpnclient mode network-extension-mode
vpnclient vpngroup abcremote password ********
vpnclient username remoteabc password ********
vpnclient enable
ntp server 192.168.224.1 source inside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:xxx
: end
can u make ur config like:
crypto ipsec client ezvpn EZVPN_Client
connect auto
group abcremote key [group key]
peer 70.140.290.117
password save
interface vlan 1
crypto ipsec client ezvpn EZVPN_Client inside
interface vlan 2
crypto ipsec client ezvpn EZVPN_Client outside
try it and let me know
good luck
Community Member
The cryptop ipsec client command is not a valid option with the ASA.
Community Member
We've seen issues with the Skinny packet inspection turned on -- pretty certain it is a bug. Try turning off that packet inspection on both ASAs, reboot the phone, and see what you get.
723
