Voip: codec mismatch
Hi...quick question:
If i'm trying to setup a call between 2 3640's and one of them is running a codec with a-law on it and the other with u-law, will it work? (i;m almost expecting the answer to be NO) why not?
If the answer is NO: then why would the calls work one-way (from a-law to u-law) but not the other way around?
Re: Voip: codec mismatch
Hi Carlos,
you must have the same codec in the common dial-peers between the routers.
Sergi Bondia.
thanks, sergi.
that's all i needed.
:o)
You can also setup a voice class for the codec. These come in handy when you have more than one codec being used in the network. Here is a link on how you configure it.
http://www.cisco.com/warp/public/788/voip/codec_complexity.html#fifth
Okey just another qucik question. What if i want to create such voice class thing for POTS dial-peer. I mean to say if someone dials with any codec and i want to match it on my terminating Access Server ?. I have many different vendors using different codec, terminating calls on us. Any suggestions
voice class apply to VoIP dial-peer both inbound and out bound. When you create a voice class with a list of codec, if some vendors they want to terninate the calls to you, his codec much match with your list.
hi!
thanks that you care to answer. yes i wanted a working config for inbound calls. here what i did and it worked....
voice class codec 1
codec preference 1 g723ar63
codec preference 2 g723ar53
codec preference 3 g723r63
codec preference 4 g723r53
codec preference 5 g729br8
codec preference 6 g729r8
codec preference 7 g726r16
codec preference 8 g728
codec preference 9 g726r24
codec preference 10 g726r32
dial-peer voice 123 voip
incoming called-number .
voice-class codec 1
dtmf-relay h245-signal
Enjoy..!!!
433
