VoIP design
Hi all,
i have to install ( for a small office ) 15 IP phone with a Call manager espress but i have few few question for you:
1) Best practise suggest to have one Vlan for IP Phone and one for PC: isn't it ?
2) Where is the best Vlan to place CM Express ? ( Voip Vlan or PC Vlan ? )
3) If i have one Layer3 switch ( with the 2 vlan configured ) and the access wan router also connected to it what is the best practise for IP phone default gateway ( router or Layer3 ) ?
Thanks in advance for your help
L.
Re: VoIP design
1 - Yes
2 - I would put CME router in voice vlan. But if the same router is being used for data and voice, then it really is not a big gain to put the router in one vlan over the other.
3 - If L3 switch has 2 SVI (vlan interfaces) configured, then you can set the L3 switch as the default gateway. On the L3 switch, you can run a default route to the WAN router as next hop. The CME can remain in the voice vlan.
Sankar.
PS: please remember to rate replies@!
Bronze
Re: VoIP design
#1 yes
#2 voip
#3 L3 Switch can be the DG for the pc/phones with default route pointing to the wan router.
U can do the following:
1. keep it simple with 2 vlans as originally plan
or if you want to be more granular
2. can add a 3rd vlan for the management vlan
3. if you have a firewall, add a 4th vlan for it.
Re: VoIP design
Thanks you for you reply,
another question:
If i have also a VG224, i have to place it also in VoIP vlan near to CME ?
Thanks again
Regards.
Re: VoIP design
That would be correct.
Re: VoIP design
I-sky,
That would sound logical to add VG224 to the same vlan.
Sankar.
Hall of Fame Super Silver
Re: VoIP design
Make sure however to configure the switchport where the vg224 is connected with "switchport access vlan ", and do not add "switchport voice vlan <>" command. The GW unlike the phones does not recognize the voice vlan so this way you can assign it to voice VLAN.
Chris
Please rate all useful posts!
288
