VoIP gateway PRI network side config
Does anyone know if a 2800 ISR will act as network side for a PRI into a Meridian option 81 ?
I seem to get TEI_Assigned when I show controllers and no Multiple_Frame_Established. Thus implying there is a L2 issue.
Any help appreciated.
1 REPLY
Re: VoIP gateway PRI network side config
This configuration is a bit old, and I am unclear on the Nortel configuration (SBC did it for us at the time), but the following worked for us on a VG200 and CMM in a 6500 chasis.
interface Serial1/1:23
no ip address
no logging event link-status
isdn switch-type primary-dms100
isdn incoming-voice voice
isdn bind-l3 ccm-manager
isdn channel-id invert extend-bit
no cdp enable
Also, make sure you are using a crossover cable for T1's (1&2,4&5) if your not already.
-Matt
108
