VoIP in a LAN
I have a study case to do and I have few questions.
The LAN on the one I must integrate the VoIP with AVVID CISCO is on an area of 10Km square (5miles square). Ethernet gigabit for the backbone fiber.
I read that only VLAN with a maxium of IP Phone by VLAN for dedicated Bandwidth is needed to ensure the Bandwidth. Does VLAN give enough Quality of service within a LAN or do I have to implement something else ? If
yes, what ?
Many Thanks for your help
Martial
Re: VoIP in a LAN
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you, or there is no public information available at this time. If you don't get a suitable response to your post, you may wish to review our resources online at http://www.cisco.com/go/solutions. You may also contact our product information line at 1-800-553-NETS or a Cisco Systems Engineer at your local Cisco office or reseller. To locate your local Cisco representative, visit http://www.cisco.com/warp/public/687/Directory.shtml
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
Re: VoIP in a LAN
VLAN is used not only to ensure bandwidth; it is also brings QoS – virtually separates Data and Voice streams/LANs.
VLAN will give you enough QoS to deploy IP Telephony.
In addition I would suggest you to bring your attention to LAN design – that’s where you need to put some logic – LAN topology design and deployment of switches that supports QoS.
And last one: it is design and topology specific - sometimes it is better to separate Voice and Data in the LAN.
There are no wright and wrong choices and solutions - it is based on what works best for customer.
I hope this help.
Vakhtang.
108
