Community Member
VoIP on a 2600 supported T1 and E1?
can a 2600 support VoIP on E1 and T1? What about VoFR?
Thank you
Re: VoIP on a 2600 supported T1 and E1?
The 26/3600s can support VoIP and VoFR using T1 and E1 telephony interfaces (NM-HDV + VWIC) configured for ISDN, T1 CAS and E1 R2.
Community Member
In addition to what Clay mentioned, if you have a Cisco 2600 series, Cisco 3660 or Cisco 3700 series, you can also use the AIM Module and a VWIC-1MFT (or VWIC-2MFT) as well... This will free up NM Slot 1 to be used for something else. If you use the NM-HDV, it will have to go into slot 1.
Check out...
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122t/122t8/ft_04gin.htm#21054
Community Member
Thank both of you!
124
