VOIP on ISDN port.
There is anybody that knows information about this connection?
We are using Cisco2600 with NM2V and VIC-2b-NT/TE configured as NT.
On port S/T-0 there is connected an ISDN adapter (EICON DIVA-USB), making call from RVS-COM telephone module, it works just making call 3 digits format.
If we make call at any pubblic network standard numbering, such like 854550011 the call is cleared for "invalid number format".
IOS version is ip-plus version 12.2.4(T);
Next there is configuration:
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname FAX_MASTER
enable password alpi$admin
ip subnet-zero
isdn switch-type basic-net3
interface Ethernet0/0
ip address 10.6.199.222 255.255.0.0
half-duplex
interface Serial0/0
no ip address
shutdown
no fair-queue
interface BRI1/0
no ip address
isdn overlap-receiving
isdn protocol-emulate network
isdn layer1-emulate network
isdn incoming-voice voice
isdn send-alerting
isdn skipsend-idverify
line-power
ip classless
ip route 0.0.0.0 0.0.0.0 10.6.200.220
no ip http server
ip pim bidir-enable
ip director cache time 60
call rsvp-sync
voice-port 1/0/0
cptone IT
voice-port 1/0/1
voice-port 1/1/0
mgcp profile default
dial-peer cor custom
dial-peer voice 1 pots
destination-pattern ^7
port 1/0/0
forward-digits all
dial-peer voice 100 pots
destination-pattern ^85
port 1/0/0
forward-digits all
prefix 00
dial-peer voice 2 pots
destination-pattern 897
port 1/0/0
forward-digits all
dial-peer voice 101 pots
destination-pattern 574573743
port 1/0/0
forward-digits all
prefix 00
dial-peer voice 102 pots
destination-pattern 0574573743
port 1/0/0
forward-digits all
prefix 0
line con 0
line aux 0
line vty 0 4
password fax
login
end
And here the error at ISDN q931 trace:
04:39:12: ISDN BR1/0: RX <- SETUP pd = 8 callref = 0x3B
04:39:12: Sending Complete
04:39:12: Bearer Capability i = 0x9090A3
04:39:12: Channel ID i = 0x83
04:39:12: Progress Ind i = 0x8083 - Origination address is non-ISDN
04:39:12: Calling Party Number i = 0x00, 0x80, '999', Plan:Unknown, Type:Unknown
04:39:12: Called Party Number i = 0x80, '854450011', Plan:Unknown, Type:Unknown
04:39:55834574847: ISDN BR1/0: Event: Received a VOICE call from 999 on B1 at 64 Kb/s
04:39:51539607552: ISDN BR1/0: Event: Accepting the call id 0xB
04:39:12: ISDN BR1/0: TX -> CALL_PROC pd = 8 callref = 0xBB
04:39:12: Channel ID i = 0x89
04:39:12: ISDN BR1/0: TX -> CONNECT pd = 8 callref = 0xBB
04:39:12: ISDN BR1/0: RX <- CONNECT_ACK pd = 8 callref = 0x3B
04:39:22: ISDN BR1/0: TX -> DISCONNECT pd = 8 callref = 0xBB
04:39:22: Cause i = 0x809C - Invalid number format (incomplete number)
04:39:22: Progress Ind i = 0x8083 - Origination address is non-ISDN
04:39:22: ISDN BR1/0: RX <- RELEASE pd = 8 callref = 0x3B
04:39:22: ISDN BR1/0: TX -> RELEASE_COMP pd = 8 callref = 0xBB
It works properly calling 3 digits number, as reported in to next:
04:40:49: ISDN BR1/0: RX <- SETUP pd = 8 callref = 0x3C
04:40:49: Bearer Capability i = 0x9090A3
04:40:49: Channel ID i = 0x83
04:40:49: Progress Ind i = 0x8083 - Origination address is non-ISDN
04:40:49: Calling Party Number i = 0x00, 0x80, '999', Plan:Unknown, Type:Unknown
04:40:49: Called Party Number i = 0x80, '743', Plan:Unknown, Type:Unknown
04:40:214748364799: ISDN BR1/0: Event: Received a VOICE call from 999 on B1 at 64 Kb/s
04:40:210453397504: ISDN BR1/0: Event: Accepting the call id 0xC
04:40:49: ISDN BR1/0: TX -> SETUP_ACK pd = 8 callref = 0xBC
04:40:49: Channel ID i = 0x89
04:40:59: ISDN BR1/0: TX -> CALL_PROC pd = 8 callref = 0xBC
04:41:01: ISDN BR1/0: TX -> CONNECT pd = 8 callref = 0xBC
04:41:01: Progress Ind i = 0x8182 - Destination address is non-ISDN
04:41:01: ISDN BR1/0: RX <- CONNECT_ACK pd = 8 callref = 0x3C
04:41:22: ISDN BR1/0: TX -> DISCONNECT pd = 8 callref = 0xBC
04:41:22: Cause i = 0x8090 - Normal call clearing
04:41:22: Progress Ind i = 0x8182 - Destination address is non-ISDN
04:41:22: ISDN BR1/0: RX <- RELEASE pd = 8 callref = 0x3C
04:41:22: ISDN BR1/0: TX -> RELEASE_COMP pd = 8 callref = 0xBC
Do you know any solution to solve this problem?
Regards Maurizio Berardo
Re: VOIP on ISDN port.
Check the prefix command. I suspect only the dial plan. Can you please check removing the prefix and dialing the whole number i.e, 008.....
It would be great if you can post the topology as well
i did, making the whole number it does the same result.
The topology is This:
There is:
PC running RVS-COM telephone application running on PC W2K ;
PC has DIVA-USB ISDN adapter connected on USB port.
Cisco 2600 has NM2V with 1 VIC2FXO (port 1/0/0 and 1/0/1) and VIC-2BRI-NT-TE (port 1/1/0 and 1/1/1 this has in Disable mode just because there isn't DSP available)
PABX connected on PSTN via E1 connection and FXS port for internal telephone connections.
PC Diva ISDN port is connected on CISCO 2600 ISDN-NT port 1/1/0.
PABX internal port is connected to Cisco 2600 1/0/0 FXO port.
To get pabx esternal line from any internal telephone there must type 0.
Regards.
193
