VOIP over frame relay problems
admin_2
Level 3
Level 3
I have installed two 1750 routers with FR 5 Link. I can talk clearly in the beginning of the conversation and during about 8 minutes, but after that time at one side cannot hear the other one. The side with problems can not hear because the voice is so interrupted. I already read the cisco document "VoIP over Frame Relay with Quality of Service" and i have these results :
I cannot applicate the RTP header compression because the FR compresion is IETF.
I can not use Frame-Relay Fragment 80 because I cannot use FR12.
I used Frame-relay cir 64000
Frame-relay BC 640
I do not hear anything in both sides, but if I use
Fram-relay BC 64000
I have the problem in one side after a few minutes.
Not applicable
First question will be if the FR link is carrying also
data packets.
If yes the fragmentation and prioritization of voice
packets is mandatory for a correct voice traffic
handling.
If no you should pay attention to the FR infrastructure and
check if the delays over the FR are constant (no jitter).
