VoIP over Frame Relay
I configured the Frame Relay connection using traffic shaping with 1 MB bw in HQ and bandwidth 64kbps with cir=48kbps in branch offices. Without traffic shaping, the connection (5 min in/out) reach 64000 bps but with traffic shaping, it dropped into 58000 bps.
the config as follow:
serial 0
encap frame-relay
fr lmi-ty ansi
fr ip rtp header compression
fr traffic-shaping
serial 0.1 point-to-point
fr int-dlci 110
ip addr 10.1.1.1 255.255.255.0
fr class VoIPovFR
map-class frame-relay VoIPovFR
fr cir 64000
fr bc 640
fr mincir 48000
fr fragment 80
fr ip rtp prority 16384 16383 64
According to cisco book,
cir is the bandwidth
mincir is the guaranteed rate.
Tc = bc/cir
10 ms = 640/64000
therefore bc = 640
fragment = 10ms * 64000/8 = 80
I tried to change the cir=48000 & the fragment=60
but then the transfer rate can only be 48000 instead of 64000. As the fragment is reduced from 80 to 60, the voice quality is dropped.
Could any one give me a help.
Re: VoIP over Frame Relay
I can't see the problem from the information you provided. You should troubleshoot this with Cisco's tech's and let me know what you come up with.
Mr. bwalchez, after I gave those traffic-shaping commands, it turns the traffic rate from 64kbps to 58kbps. It means I lost 4000 bps.
And where is cisco's tech's ?
http://www.cisco.com/tac/caseopen
Come back after they help you and let us know what you came up with.
FRF12 fragmentation is going to put an overhead on the data stream. Each FRF12 fragment is going to require a header! This may account for the loss of the 4K. Try increasing the fragment size - hence reducing the overhaed. But watch out - increasing the fragment size may reduce voice quality.
Another thing you can try is RTP header compression. This can reduce the voip streams down from 32K to 12K.
cheers
Derek...
There is a recommendation what say that fragment seize with Ip rtp header compresison >= 80 for dont lose quality voice.
Other recomendation is cir = bandwidth in your case
cir = 48000 , but if you use frame relay adaptive shapping then cir= 64000 and mincir =48000 but isnt recommendable
251
