10-31-2001 07:16 AM - edited 03-12-2019 01:07 PM
I am having some qos issues with voip over frame with 4 voice ports using FXS and FXO ports. The main problem I am having is with echo. Can someone please give me a basic idea of how to config this?
I am using traffic shaping and echo cancelling and everything I can think of, am i missing something?
thanks very much!
10-31-2001 09:12 AM
You can also look at the DB levels. If the FXO/FXS Db level are too high the echo cancel will not help.
-lef
11-06-2001 01:57 PM
good link for troubleshooting echo
http://www.cisco.com/univercd/cc/td/doc/cisintwk/intsolns/voipsol/ea_isd.htm
11-06-2001 05:36 PM
thank you , i did use this info..it did help my echo problem, now I am having a voice quality problem.
I am told that the confersations "cut" in and out periodically. I do have some qos settings and have the voice prioritized. It is not a traffic problem either..the data link is only about 15 or 20% utilized. Please help!
Ron
