VOIP Problem
I have a problem with the VOIP I deployed. I found out that calls are not dropped on the fxo ports when the user drops until almost 5 minutes after. What command can i specify on the router to stop this
1 REPLY
Re: VOIP Problem
The problem you encount is a common problem that the call can not drop when using the fxo ports, you can refer the following links two solve your porblem:
http://www.cisco.com/warp/public/788/signalling/fxo_disconnect.html#2
86
