Silver
Voip problem
When we make calls through a high-density voice (NM-HDV-1E1-30E) module to PSTN, call setup is established, but voice does not pass through.
Our gateway is a Cisco3620 (IOS: 12.2.10) and it's connected to a PBX through the NM. The PBX can reach external phone numbers through digital and analog lines, the problem appears when we use the analog lines.
Is this a DSP problem? Any idea?
Regards.
Re: Voip problem
Not enough info here. What type of signaling, wat is the topology, how does the pbx fit into the picture? What does the config look like?
Silver
Re: Voip problem
We are using E1 PRI.
Analog Phone --------- Cisco3620 -------------- PBX ---- PSTN
The config:
controller E1 0/0
pri-group timeslots 1-31
interface Serial0/0:15
no ip address
no logging event link-status
isdn switch-type primary-net5
isdn incoming-voice voice
isdn T309-enable
no cdp enable
voice-port 0/0:15
cptone ES
dial-peer cor custom
dial-peer voice 1000 pots (interface to the PBX)
destination-pattern .T
progress_ind progress enable 8
direct-inward-dial
port 0/0:15
229
