VoIP problem
Good day to all forum members. I just want to ask help from you guys regarding our VoIP setup (actually we are using frame relay connection) with a speed rate if 19.2K CIR and burst to 64k. My problem is that whenever there is a large amount of data passing thru the line while a voice call is in progress, voice distortion would occur and we cannot hear each other anymore (voice would become garble). Is there an IOS command for a bandwidth reserve for voice? Pls help. tnx.
Re: VoIP problem
This would require QoS (Quality of Service) on the line. Please see
http://www.cisco.com/en/US/customer/tech/tk652/tk698/technologies_configuration_example09186a0080094af9.shtml
What type of eqiupment do you have at each end?
Blue
Re: VoIP problem
----------- WAN QOS FOR POINT-TO-POINT T1 ------------
-- Apply to Serial interfaces at both ends.
-- Adjust priority queue bandwidth number (700k in this example)
-- to match expected call volume.
-- You can add "ip rtp header-compression" on the serial
-- interfaces on both ends as well but I have found that in
-- some cases this degrades voice quality when users listen
-- to voicemail.
class-map match-all control
match access-group 192
class-map match-all voice
match access-group 191
policy-map OUTGOING-POLICY
class voice
priority 700
class control
bandwidth 32
class class-default
fair-queue
interface Serial1/0
service-policy output OUTGOING-POLICY
access-list 191 permit ip any any precedence critical
access-list 192 permit ip any any precedence flash
Anonymous
N/A
Re: VoIP problem
Sir I have a 3640 and 1751 at the other end.
Re: VoIP problem
this of must help you
http://www.cisco.com/pcgi-bin/Support/browse/psp_view.pl?p=Internetworking:Voice:QoS
also you must use codec g723 and rtp header-compression
interface s0/0.xxx point-to-point
frame-relay ip rtp header-compression
dial-peer voice xxx voip
destination-pattern xxxxx
session target xxxxx
codec g723ar63
this consumes 8Kpbs by call
J.R-
176
