Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
voip problem
I have two 827-4v and since him I activate QoS's commands, when I realize a call of one to other one, it is late 10 seconds in the telephone begins to ring in the destiny. There is form of which the call is realized more rapid and not with this delay of 10 seconds?
Re: voip problem
Sounds like you dial-peers are not granular enough or you have overlapping dial-peers. What I mean by that is 1 dial-peer with destination pattern of 123 and another with 1234. If you dial 123 the router waits 10 seconds to see if you will enter the 4 or not. Simple explaination but may apply to your situation.
Thank you,
-Mckee
Re: voip problem
I am afraid that it is not it, first because I have gone down the time of interdigits to 2 seconds and continues being late 10, and second because my 4 destination pattern have the same destiny, which is 2, and they all go to the same ip of destiny.
Do you think about another possible reason for my problem
Thank you,
Alejandro.
82
