Voip problems with a router 2650 and a PBX Nec
I have a Cisco Router 2650 with two E&M interface cards (total: 4 ports) from which two ports are connected to a PBX Nec model M100 by an E&M Type V conection on 4 wires.
The problem is that the E&M lines from the PBX remain taken (captured) at random and we have to reset the PBX cards to bring it into service again.
The router configuration is :
Current configuration : 4705 bytes
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname voip
ip subnet-zero
no ip finger
call rsvp-sync
voice service voip
h323 call start fast
interface FastEthernet0/0
speed 10
half-duplex
h323-gateway voip interface
h323-gateway voip id voip
h323-gateway voip h323-id voip
interface Serial0/0
no ip address
encapsulation frame-relay
no fair-queue
frame-relay traffic-shaping
interface Serial0/0.121 point-to-point
bandwidth 768
ip address
frame-relay class xxx
frame-relay interface-dlci 121
interface Serial0/1
no ip address
shutdown
map-class frame-relay xxx
frame-relay traffic-rate 668000 768000
no frame-relay adaptive-shaping
voice-port 1/0/0
auto-cut-through
echo-cancel coverage 32
cptone AR
timeouts interdigit 5
timing digit 128
timing inter-digit 128
operation 4-wire
type 5
signal immediate
voice-port 1/0/1
auto-cut-through
cptone AR
timing digit 128
operation 4-wire
type 5
signal immediate
voice-port 1/1/0
shutdown
voice-port 1/1/1
shutdown
dial-peer cor custom
dial-peer voice 100 pots
destination-pattern 54T
port 1/0/0
prefix ,
dial-peer voice 101 pots
port 1/0/1
prefix ,
dial-peer voice 310 voip
destination-pattern 31.
max-redirects 2
session target ras
gateway
line con 0
transport input none
line aux 0
line vty 0 4
login
no scheduler allocate
end
Which paramaters or signals could I verify in the router??
I would be grateful if you could respond to me as soon as possible.
Thanks in advance for your help.
Kind regards
Re: Voip problems with a router 2650 and a PBX Nec
When a port gets stuck, do a show voice port summary to see what the status of the ports are on the router. Also, check that the router signal ground (pin 8) has good continuity to the signal ground of the PBX.
I' ve checked the router signal ground and has a good continuity to the signal ground of the PBX.
This is the show voice port summary when a port gets stuck
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
1/0/0 -- e&m-imd up up idle seized y
1/0/1 -- e&m-imd up up seized seized y
1/1/0 -- e&m-wnk down down idle idle y
1/1/1 -- e&m-wnk down down idle idle y
What does the Status "seized" of the E&M port mean ?
297
