VoIP QOS over 10mb Lan Extension.
We've got a 10mb Lan extension between two sites and we are going to start running Voice between them. What is the best way to prioritize the voice traffic between the two sites? the Lan extension runs fro router to Router via the ethernet ports. There will be two Vlans voice and Data.
Gus
Bronze
Re: VoIP QOS over 10mb Lan Extension.
Let me guess, are you use Wireless connection??
If thats the case, you really dont need QoS on ethernet interface. However, you can configure LLQ between 2 sites and apply "policy-map" at the Ethernet interface.
According cisco website, we really dont need LLQ on ethernet, it is because ethernet interface is faster than serial interface.
Correct me if I am wrong.
Ken
It's not wireless. It's a service BT supply if your two sites are on the same exchange. it's just a straight wire between the two routers. We tried two voice calls at G711 and transfered a lot of data and there were a few dropped voice packets.
I'll have a look at applying LLQ.
Bronze
If you have few dropped voice packets, I think you have to apply LLQ. Before apply LLQ, you have to "mark the traffic" and configure different VLAN just for voice. It really depends what kind of Cisco switch you have.
If you have switch that can do CoS-to-DSCP
Configure mapping and QoS on switch:
qos map cos 3 to dscp 26
qos map cos 4 to dscp 34
qos map cos 5 to dscp 46
interface FastEthernet3/4
switchport access vlan 4 <-- data vlan
switchport mode access
switchport voice vlan 6 <-- voice vlan
duplex full
qos trust cos
tx-queue 3
priority high
spanning-tree portfast
configure LLQ on router:
class-map match-all voice
match ip dscp ef
class-map match-all signaling
match ip dscp af31
policy-map voice-priority
class voice
priority percent 33
class signaling
bandwidth percent 2
class class-default
fair-queue
interface Serial0/1:0
bandwidth 1544
ip address 192.168.254.57 255.255.255.252
encapsulation ppp
no ip route-cache
service-policy output voice-priority <-- apply llq
If you switch doesnt have CoS-to-DSCP mapping capability (still need QoS on FastEthernet on switch), you have do mapping and LLQ both on router:
class-map match-all EF <--mapping
match ip dscp ef
class-map match-all AF31
match ip dscp af31
class-map match-all cos5
match cos 5
class-map match-all cos3
match cos 3
class-map match-all voice <--llq
match ip dscp ef
match ip dscp af31
policy-map map-cos-to-dscp <--mapping
class cos5
set ip dscp ef
class cos3
set ip dscp af31
class class-default
set ip dscp default
policy-map map-dscp-to-cos <--mapping
class EF
set cos 5
class AF31
set cos 3
class class-default
set cos 0
policy-map voice-priority <--llq
class voice
bandwidth percent 33
class signaling
bandwidth percent 2
class class-default
fair-queue
interface FastEthernet1/0.6
description west_hall_VOIP_vlan
encapsulation dot1Q 6
ip address 10.3.6.1 255.255.254.0
ip helper-address 10.0.0.20
service-policy input map-cos-to-dscp <--apply mapping
service-policy output map-dscp-to-cos <--apply mapping
interface ethernet 0/0
ip address 192.168.254.146 255.255.255.252
service-policy output voice-priority <--apply llq
I hope those configurations are not confuse you.
Let me know if you need help.
147
