VOIP question
I just got two FXS card for my 2611(64/16) and 2610(24/8), The IOS of 2611 is enterprise version. I connected 2611 and 2610 with the ethernet ports with a cross-over RJ45 cable and the ping is ok.
now when I want to configure the voice card, i use the following command,
2611#dial-peer voice 1 pots
desti 1111
next step, i should enter "port" command, but no "port" command, Why? is this a problem of IOS? or not.
thanks
Re: VOIP question
Under 'show ver' , do you see 2 FXS ports, etc?
Under 'show run' do you see voice-port like:
voice-port 1/0
voice-port 1/1
Re: VOIP question
The version you need is Plus so it should have been Enterprise Plus. Without the Plus image your routers will not recogonize the voice hardware.
Javed
91
