Community Member
VOIP question
I just got two FXS card for my 2611(64/16) and 2610(24/8), The IOS of 2611 is enterprise version. I connected 2611 and 2610 with the ethernet ports with a cross-over RJ45 cable and the ping is ok.
now when I want to configure the voice card, i use the following command,
2611#dial-peer voice 1 pots
desti 1111
next step, i should enter "port" command, but no "port" command, Why? is this a problem of IOS? or not.
Community Member
Re: VOIP question
when you do a "show version" do you see "4 Voice FXS ports" in the list?
What version is the IOS?
If they don't show up in show version & the IOS is late 12.1 or 12.2 or 12.3
-- you might try reseating the VICs in the NM-2V network module slots & reseat the voice network module in the NM slot... Maybe it doesn't have a good connection...
Community Member
Re: VOIP question
2611#sh ver
IOS (tm) C2600 Software (C2600-J1S3-M), Version 12.3(1a), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Fri 06-Jun-03 22:08 by dchih
Image text-base: 0x80008098, data-base: 0x819BDAE0
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
2611 uptime is 5 hours, 59 minutes
System image file is "flash:c2600-j1s3-mz.123-1a.bin"
cisco 2611 (MPC860) processor (revision 0x203) with 61440K/4096K bytes of memory
Processor board ID JAD05330RT4 (4264869256)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
TN3270 Emulation software.
2 Ethernet/IEEE 802.3 interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
for the 2611, i think the IOS and the memory(64/16) are ok, for the 2610, maybe the IOS is not good, just 11.3, right now, i am waiting the new memory coming, but i think the 2611 should be no problem, but i can not give "port" command, i don't know why?
Community Member
Re: VOIP question
You are running an Enterprise Basic feature set. Try running a Plus feature set of IOS. You can see the router is probably detecting the hardware by doing show diag, but since it does not has the proper IOS it won't show the voice hardware in the config.
I hope that helps.
Community Member
Re: VOIP question
Also for 11.3 if you choose an basic IP Plus IOS you should be able to run voip.
