VoIP Re-Routing
How can I configur my dial-peer in such a way taht if the session target IP addess fails the daile peer uses another session target IP.
for example: If I want to dial a remote peer at destenation pattern 200 with a session target IP address of 163.121.203.2, if this session target address fails I want to reach the remote peer (200) through another session target IP address of 62.240.107.2.
  • Other Collaboration Voice and Video Subjects
Re: VoIP Re-Routing
Create another dial peer with the new session target and give it a lower preference.
Re: VoIP Re-Routing
first you should change the tcp establish timer (default 15 seconds)
voice class h323 1
h225 timeout tcp establish 3
then do your primary dial peer
dial-peer voice xxx voip
destination-pattern 123
voice-class h323 1
session target ipv4:x.x.x.x
then your alternate dial peer
preference 1
regards
Sam
122
