voip solution
can you provide a VOIP solution for a callshop with 14 phone booths currently using analogue pstn connection. service is currently provided by international carriers over the analogue lines using indirect access. A detailed solution will be very much appreciated as my technical knowledge is basic.
Re: voip solution
This can be done many different ways and an informed recommendation would require more information.
For example
What is your budget?
What features will you require?
What is the potential for growth?
Do you need voicemail?
etc.....
a detailed solution requires a detailed understanding of the environment
Re: voip solution
Dear kola bankole,
It is all depends of the bandwidth type you have between your store and public which will determine the exact solution.
I would suspect that an ATA 186 would do the job.
Feel free to go to www.iconnecthere.com web site to find a bit more about the possibilities and if you are interested, I will be happy to assist you off-line
yaron@deltathree,com
92
