VOIP SYSTEM
I have a office in Germany (HQ) and office in India.
In both the offices 3 pesons are working.
I need to cummunicate within these offices and both the offices can dail & receive local call of other ends.
I mean a employees of German office can call any phone in India and receive calls from India.
And vice-versa for employees of India.
What do I need at both ends to make this work?
What hardware? Software? Phones?
Re: VOIP SYSTEM
this can be done in a number of ways and what you decide in most cases will primarily be driven by budget. It seems like too small an environment for Call Manager, so you may want to look at Call manager express and unity express
http://cisco.com/en/US/products/sw/voicesw/ps4625/index.html
http://cisco.com/en/US/products/sw/voicesw/ps5520/index.html
these will allow you to use IP Phones. the call processing and voicemail will run in a router chassis.
Then what type of link you have, whether it's a private,point to point link between offices or if you want to do it over the internet, will dictate the rest of the design. Will you have a private link? you may be able to get away with a vpn over the internet between offices.
You could, with a small key system in one or both locations just use analog phones, establish a vpn over the internet and have a few analog ports at each site and acomplsh the same thing.
Again alot depends on budget, type of link, features needed, call volume between locations and at each location etc..
Re: VOIP SYSTEM
I can`t spend much.
What about if I purchase Cisco 2600 and FXS/FXO cards form the "EBAY", will it work?
Can you tell me the minimum possible Hardware & Software requirement (which I can purcase from the EBAY) ?.
81
