VoIp technical help needed!!!
I need some urgent help.
I am kindly asking for some technical information on the implementation of VOIP Solution over Satellite, especially on a private network with a hub and more than six remote sites.
Explore the possibility of interfacing VOIP with terresterial PSTN Network. Indicate the technology and what is required.
This particular network should be able to send Fax, Voice and Data.
1 REPLY
Hall of Fame Super Silver
Re: VoIp technical help needed!!!
CallManager centrelized call processing would be the best solution, with redundant CallManagers at the hub site along with Unity voicemail or any other voicemail you choose to implement. Depeding on the size of the remote sites I would suggest going with 2811/21/51 routers with voice hardware such as PVDMs (Digital Signal Processors), VWIC-MFT-T1/E1 and/or FXO cards depending on the interface to PSTN. Start out by reading the CCM 4.0/4.1 Cisco SRND which can be found at www,cisco.com/go/srnd
Please rate all helpful posts!
Chris
109
