VoIP to VoIP calls using AS5400HPX
I have been banging my head against the wall for the past three daays trying to get voip to voip calls to work over a n AS5400HPX. No matter what I try with regards to dial-peers, I cannot get an incoming H323 call to call into a SIP-server.
The call comes into the right dial-peer, gets translated correctly (digit stripping), and the should call out through a dial-peer using SIP. But instead, the call always gets routed out the POTS dial-peer. If I remove the POTS dial-peer, the call dies.
If anyone knows how to do this, or what is required to do this I would greatly appreciate the help.
Kindest regards to all,
Joe
1 ACCEPTED SOLUTION
Re: VoIP to VoIP calls using AS5400HPX
Try:
voice service voip
allow-connections sip to h323
allow-connection h323 to sip
It is available in:
c5400-is-mz.123-11.T7.bin (IP Plus)
Let me know if this helps by rating the post.
Michael
Try:
voice service voip
It is available in:
Michael
Thanks Michael. Your suggestion solved the problem. I knew the commands existed, but was not sure which IOS image I could find them in. We were also very pleasantly surprised sicne several people at Cisco said that 12.4 would be the minimum for this to work.
Joe
97
