VOIP trunking config using PRI's
I need a complete configuration example for VOIP trunking of 2 PRI's across a 100Mbps IP WAN link between 2 7206VXR routers using a single D-channel for all 48 channels, supporting voice, fax, and modem traffic.
Re: VOIP trunking config using PRI's
Router 1 Configuration Router 2 Configuration
Controller T1 2/1
ds0-group 0 timeslots 1 type ext-sig
ds0-group 1 timeslots 2 type ext-sig
ds0-group 2 timeslots 3 type ext-sig
ds0-group 3 timeslots 4 type ext-sig
ds0-group 4 timeslots 5 type ext-sig
ds0-group 5 timeslots 6 type ext-sig
ds0-group 6 timeslots 7 type ext-sig
ds0-group 7 timeslots 8 type ext-sig
ds0-group 8 timeslots 9 type ext-sig
ds0-group 9 timeslots 10 type ext-sig
ds0-group 10 timeslots 11 type ext-sig
ds0-group 11 timeslots 12 type ext-sig
ds0-group 12 timeslots 13 type ext-sig
ds0-group 13 timeslots 14 type ext-sig
ds0-group 14 timeslots 15 type ext-sig
ds0-group 15 timeslots 16 type ext-sig
ds0-group 16 timeslots 17 type ext-sig
ds0-group 17 timeslots 18 type ext-sig
ds0-group 18 timeslots 19 type ext-sig
ds0-group 19 timeslots 20 type ext-sig
ds0-group 20 timeslots 21 type ext-sig
ds0-group 21 timeslots 22 type ext-sig
ds0-group 22 timeslots 23 type ext-sig
ds0-group 23 timeslots 24 type ext-sig
voice-port 2/1:0
connection trunk 200
voice-port 2/1:1
connection trunk 201
voice-port 2/1:2
connection trunk 202
voice-port 2/1:3
connection trunk 203
voice-port 2/1:4
connection trunk 204
voice-port 2/1:5
connection trunk 205
voice-port 2/1:6
connection trunk 206
voice-port 2/1:7
connection trunk 207
voice-port 2/1:8
connection trunk 208
voice-port 2/1:9
connection trunk 209
voice-port 2/1:10
connection trunk 210
voice-port 2/1:11
connection trunk 211
voice-port 2/1:12
connection trunk 212
voice-port 2/1:13
connection trunk 213
voice-port 2/1:14
connection trunk 214
voice-port 2/1:15
connection trunk 215
voice-port 2/1:16
connection trunk 216
voice-port 2/1:17
connection trunk 217
voice-port 2/1:18
connection trunk 218
voice-port 2/1:19
connection trunk 219
voice-port 2/1:20
connection trunk 220
voice-port 2/1:21
connection trunk 221
voice-port 2/1:22
connection trunk 222
voice-port 2/1:23
connection trunk 223
dial-peer voice 100 pots
destination-pattern 100
port 2/1:0
dial-peer voice 101 pots
destination-pattern 101
port 2/1:1
dial-peer voice 102 pots
destination-pattern 102
port 2/1:2
dial-peer voice 103 pots
destination-pattern 103
port 2/1:3
dial-peer voice 104 pots
destination-pattern 104
port 2/1:4
dial-peer voice 105 pots
destination-pattern 105
port 2/1:5
dial-peer voice 106 pots
destination-pattern 106
port 2/1:6
dial-peer voice 107 pots
destination-pattern 107
port 2/1:7
dial-peer voice 108 pots
destination-pattern 108
port 2/1:8
dial-peer voice 109 pots
destination-pattern 109
port 2/1:9
dial-peer voice 110 pots
destination-pattern 110
port 2/1:10
dial-peer voice 111 pots
destination-pattern 111
port 2/1:11
dial-peer voice 112 pots
destination-pattern 112
port 2/1:12
dial-peer voice 113 pots
destination-pattern 113
port 2/1:13
dial-peer voice 114 pots
destination-pattern 114
port 2/1:14
dial-peer voice 115 pots
destination-pattern 115
port 2/1:15
dial-peer voice 116 pots
destination-pattern 116
port 2/1:16
dial-peer voice 117 pots
destination-pattern 117
port 2/1:17
dial-peer voice 118 pots
destination-pattern 118
port 2/1:18
dial-peer voice 119 pots
destination-pattern 119
port 2/1:19
dial-peer voice 120 pots
destination-pattern 120
port 2/1:20
dial-peer voice 121 pots
destination-pattern 121
port 2/1:21
dial-peer voice 122 pots
destination-pattern 122
port 2/1:22
dial-peer voice 123 pots
destination-pattern 123
port 2/1:23
dial-peer voice 200 voip
destination-pattern 2..
vad
signal-type cas
dtmf-relay cisco-rtp
codec g711ulaw
Controller T1 2/1
voice-port 2/1:0
connection trunk 100 answer-mode
voice-port 2/1:1
connection trunk 101 answer-mode
voice-port 2/1:2
connection trunk 102 answer-mode
voice-port 2/1:3
connection trunk 103 answer-mode
voice-port 2/1:4
connection trunk 104 answer-mode
voice-port 2/1:5
connection trunk 105 answer-mode
voice-port 2/1:6
connection trunk 106 answer-mode
voice-port 2/1:7
connection trunk 107 answer-mode
voice-port 2/1:8
connection trunk 108 answer-mode
voice-port 2/1:9
connection trunk 109 answer-mode
voice-port 2/1:10
connection trunk 110 answer-mode
voice-port 2/1:11
connection trunk 111 answer-mode
voice-port 2/1:12
connection trunk 112 answer-mode
voice-port 2/1:13
connection trunk 113 answer-mode
voice-port 2/1:14
connection trunk 114 answer-mode
voice-port 2/1:15
connection trunk 115 answer-mode
voice-port 2/1:16
connection trunk 116 answer-mode
voice-port 2/1:17
connection trunk 117 answer-mode
voice-port 2/1:18
connection trunk 118 answer-mode
voice-port 2/1:19
connection trunk 119 answer-mode
voice-port 2/1:20
connection trunk 120 answer-mode
voice-port 2/1:21
connection trunk 121 answer-mode
voice-port 2/1:22
connection trunk 122 answer-mode
voice-port 2/1:23
connection trunk 123 answer-mode
dial-peer voice 200 pots
destination-pattern 200
port 2/1:0
dial-peer voice 201 pots
destination-pattern 201
port 2/1:1
dial-peer voice 202 pots
destination-pattern 202
port 2/1:2
dial-peer voice 203 pots
destination-pattern 203
port 2/1:3
dial-peer voice 204 pots
destination-pattern 204
port 2/1:4
dial-peer voice 205 pots
destination-pattern 205
port 2/1:5
dial-peer voice 206 pots
destination-pattern 206
port 2/1:6
dial-peer voice 207 pots
destination-pattern 207
port 2/1:7
dial-peer voice 208 pots
destination-pattern 208
port 2/1:8
dial-peer voice 209 pots
destination-pattern 209
port 2/1:9
dial-peer voice 210 pots
destination-pattern 210
port 2/1:10
dial-peer voice 211 pots
destination-pattern 211
port 2/1:11
dial-peer voice 212 pots
destination-pattern 212
port 2/1:12
dial-peer voice 213 pots
destination-pattern 213
port 2/1:13
dial-peer voice 214 pots
destination-pattern 214
port 2/1:14
dial-peer voice 215 pots
destination-pattern 215
port 2/1:15
dial-peer voice 216 pots
destination-pattern 216
port 2/1:16
dial-peer voice 217 pots
destination-pattern 217
port 2/1:17
dial-peer voice 218 pots
destination-pattern 218
port 2/1:18
dial-peer voice 219 pots
destination-pattern 219
port 2/1:19
dial-peer voice 220 pots
destination-pattern 220
port 2/1:20
dial-peer voice 221 pots
destination-pattern 221
port 2/1:21
dial-peer voice 222 pots
destination-pattern 222
port 2/1:22
dial-peer voice 223 pots
destination-pattern 223
port 2/1:23
dial-peer voice 100 voip
destination-pattern 1..
vad
signal-type cas
codec g711ulaw
ROUTER2:
Controller T1 2/1
voice-port 2/1:0
voice-port 2/1:1
voice-port 2/1:2
voice-port 2/1:3
voice-port 2/1:4
voice-port 2/1:5
voice-port 2/1:6
voice-port 2/1:7
voice-port 2/1:8
voice-port 2/1:9
voice-port 2/1:10
voice-port 2/1:11
voice-port 2/1:12
voice-port 2/1:13
voice-port 2/1:14
voice-port 2/1:15
voice-port 2/1:16
voice-port 2/1:17
voice-port 2/1:18
voice-port 2/1:19
voice-port 2/1:20
voice-port 2/1:21
voice-port 2/1:22
voice-port 2/1:23
port 2/1:0
port 2/1:1
port 2/1:2
port 2/1:3
port 2/1:4
port 2/1:5
port 2/1:6
port 2/1:7
port 2/1:8
port 2/1:9
port 2/1:10
port 2/1:11
port 2/1:12
port 2/1:13
port 2/1:14
port 2/1:15
port 2/1:16
port 2/1:17
port 2/1:18
port 2/1:19
port 2/1:20
port 2/1:21
port 2/1:22
port 2/1:23
vad
signal-type cas
codec g711ulaw
Thanks much. So this looks like I'm just passing all 48 channels straight through. I don't have to configure an ISDN switch type, PRI parameters or NFAS??
206
