Community Member
VOIP using FXO
I have a doubt regarding Voice over IP communication.
Consider the scenarion two remote places connected through a leased circuit using 36xx series routers and i need to enable voice. will the following solution work .
The two routers will be connected over a fractional T1 line and each have a FXO card and one port connected to EPBX. Will this solution enable multiple users(connected to EPBX) to make calls simulatneously or does each voice call need to be routed through a individual FXO connection .
Please also let me know if there are any case studies available .
1 REPLY
Re: VOIP using FXO
Each voice port can handle one call. To work around this you can install a T1 card to the 36XX to handle more. Here is a link-
http://www.cisco.com/warp/public/788/products/2fxo_vic.html
Since the FXO appears to be a phone to the PBX, it can only handle one call like a phone line.
103
