VOIP USING VEGA50
We are evaluting a VOIP system for out network what we have is Vega 50 unit made by vegastream which allows u to connect standard analog telephone to run over IP. This will be implemented over wan sites so obvisouly we need routers at both end to terminate the serial line. We also want to have QOS running as over this serial line we will be running standard data overthe link on top voip stuff. We wonder which QOS of service will be suitable eg RTP, IP predence or RSVP.
also they documents which explain the different protocol as someone has told me RTP is not suitable for VOIP as it UDP. here is the exact quote i have been given which doesnt make sense The advantage of this is that there is no retries which
are not very useful in VoIP and it's resilient to individual link failure. I orginally wanted to use RTP but due to this statement i bit lost.
also cani havesome config for qos for voip
cheers
Re: VOIP USING VEGA50
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you, or there is no public information available at this time. If you don't get a suitable response to your post, you may wish to review our resources at the online http://www.cisco.com/go/solutions. You may also contact our product information line at 1-800-553-NETS or a Cisco Systems Engineer at your local Cisco office or reseller. To locate your local Cisco representative, visit http://www.cisco.com/warp/public/687/Directory.shtml
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
Silver
86
СоздатьДля создания публикации, пожалуйста в систему
