VT Advantage installed, no outside calls working
Installed VT Advantage and "Enabled" video for my phone. Now, if the VTA app is loaded, I can't make outside calls. Shutdown the app, I can make all calls.
We use MGCP and ISDN BRI to outside call
Here are traces:
VT advantages OFF
Dec 20 10:16:13.852: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8 callref = 0x27
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x8A
Calling Party Number i = 0x0081, '3307'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '0123456789'
Dec 20 10:16:14.184: ISDN BR0/1/0 Q931: RX <- SETUP_ACK pd = 8 callref = 0xA7
Channel ID i = 0x8A
Dec 20 10:16:14.300: ISDN BR0/1/0 Q931: RX <- CALL_PROC pd = 8 callref = 0xA7
Dec 20 10:16:20.480: ISDN BR0/1/0 Q931: RX <- ALERTING pd = 8 callref = 0xA7
Dec 20 10:16:22.632: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8 callref = 0x27
Cause i = 0x8090 - Normal call clearing
Dec 20 10:16:22.848: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8 callref = 0xA7
Dec 20 10:16:22.852: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x27
VT advantages ON
Dec 20 10:16:24.940: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/1/0, TEI 0 changed to down
Dec 20 10:16:24.960: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/1/0, TEI 0 changed to up
Dec 20 10:16:25.264: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8 callref = 0x28
Bearer Capability i = 0x8080A5
Standard = CCITT
Transfer Rate = Packet - not specified
Channel ID i = 0x8A
Dec 20 10:16:25.404: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xA8
Cause i = 0x82C1 - Bearer capability not implemented
Dec 20 10:16:27.404: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/1/0, TEI 0 changed to down
Dec 20 10:16:27.424: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/1/0, TEI 0 changed to up
I have applied the bearer-cap Speech
seen on
https://puck.nether.net/pipermail/cisco-voip/2005-July/006221.html
and http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=IP%20Communications%20and%20Video&topic=Video%20over%20IP&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1dd6ddbf/0#selected_message
and
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080569b65.shtml
but it doens't work :/
Is there workaround ?
Thank you for your help.
Best regards.
  • Other Collaboration Voice and Video Subjects
Silver
Re: VT Advantage installed, no outside calls working
For this issue I believe that you may be running into an issue, bug CSCsb90459.
Turn off CVTA before making call or disable Video on IPPhone
When VT Advantage is active, gateway sends ISDN Setup witch bearer capability "0x8080A5"
[Information Transfer Capability: Speech ; Transfer Mode: Packet mode] and the PABX
rejects connections (ISDN cause code "incompatibile destination").
When VT Advantage is off, bearer capabililty is "0x9090A3" and connectivity works fine.
The fix for this is the ES 37 on callmanger 4.1.3. It is not in SR2 as ES 37 was created afterwards.
Exactly !
it's confirmed by a case.
Thank you.
I guess you could fix this problem on the gateway by forcing bearer-cap speech on the voice port of gw. In the voice port config mode enter "bearer-cap speech".
This workaround was documented long ago in the following article http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a0080093f62.shtml#Solution2
no, the workaround "bearer-cap speech" doesn't work in our case.
197
