vt advantage problems with 7970 and ipcommunicator
hi!! everybody...
l have a problem, l have to coexist the ip phone 7940, 7960, 7970 and ip communicator(version 2.0.1.1), with vt advantage, but it isn't working fine.
l checked on ccm, badwidth, region, firmware and l think that all it's OK
l did some test with the past version of vt advantage 1.0.2 and all work fine except the ipcommunicator, but the problem is that the ipcommunicator need the vt advantage version 2.0.1a for work video and the results with this version at follow:
ip phones video
7960 7960 ok
7960 ipcom ok
ipcom ipcom ok
7960 7970 fail
7970 ipcom fail
7970 7970 fail
now!!! the problem is the 7970
and l did some test with the new version of vt advantage 2.0.2 and it doesn't work fine
if somebody can help me about this problem please
THANKS A LOT =)
  • Other Collaboration Voice and Video Subjects
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: vt advantage problems with 7970 and ipcommunicator
Hi Karina,
Maybe you are hitting this bug that effects 7970 phones with VT Advantage, have a look it seems like the latest 7970 firmware fixes the problem;
CSCse36933 Bug Details
Release Notes
Symptom:
CUVA 2.0(1) does not work with combination of 7941/7961/7970/7971 phones and CCM 4.1(3)/4.1(3)sr2
The problem does not occur in CCM 4.2 and CCM 5.0
The problem also does not occur when a 7940/7960 Phone is swapped in place of the 7970 - pointing more than likely towards a Phone problem
Conditions:
CUVA 2.0(1) with CCM 4.1(3)/4.1(3)sr2 with 7941, 7961, 7970 or 7971 phones.
Workaround:
Upgrade IP Phone to the latest firmware found in CCO.
797x phone firmware:
http://www.cisco.com/cgi-bin/tablebuild.pl/ip-7900ser. Tested with 'cmterm-7970-7971-sccp.8-0-3.zip'.
7941/7961 phone firmware:
http://www.cisco.com/cgi-bin/tablebuild.pl/ip-7900ser. Tested with 'cmterm-7941-7961-sccp.8-0-3.zip'
Hope this helps!
Rob
Please remember to rate helpful posts.....
"May your heart always be joyful And may your song always be sung May you stay forever young " - Dylan
Hi Karina,
Release Notes
Symptom:
Conditions:
Workaround:
Hope this helps!
Rob
thanks a lot rob :)
l'm going to do some test this week about your suggestion.
anything, l'm will saying you ok
bye
hi! rob...
the problem was solve with the latest version of 7970 firmware (sccp.8-0-3), l did some test with all phones and the vt advantage work fine.
thanks a lot
take care =)
Hi Karina,
No worries! Glad to help.
Take care!
Rob
154
