I would like to know if I can use the VWIC-2MFT-T1 card for Voice and Data at the same time? For example one T1 Port for Data and another T1 port for Voice(PRI) on a Cisco 1760-V router.....
It should work fine as long as you provision the proper DSP's in the 1760 to handle the voice T1. The controllers can be configured to handle PRI (pri group) or Data (ds0 group). Take a look at the matrix:
