The reason is that by default the AIM is clocked on the internal PLL. Just add the following two command on the 2651xm (if VWIC in wic slot 0 of course)
network-clock-participate wic 0
network-clock-select 1 E1 0/0
The only problems I had on the issue was that fax calls were failing.
kind regards
Bart
