vwic with AIM card
tdhaliwal
I have VWic-1MFT-T1 installed in WIC 0 slot as well as AIM-voice-30 installed on the motherboard of 2611XM router. What is the config for AIM to work so the T1 can start using those DSP resources. Also the network-clock-participate wic0 is the referring to AIM or Vwic-MFT-T1?
This is what i have so far:
network-clock-participate wic 0
network-clock-select 1 T1 0/0
gregg.davis
network-clock-participate aim 0 (slot#)
Thanks for the response. I'm not able to see the second command with aim 0. Only option i have is wic or slot#. I'm running 12.2.15zj3 code. Please let me know what i'm missing.
The 2600 doesn't have the keyword as there is only one AIM slot so it is implicit that it is to be used as a DSP resource. You do need the keyword as there are multiple WIC slots. Make sure you also add the network-clock-select t1 0/0 keyword as well.
Thanks. So all i need is network-select-clock t1 0/0 to make this work.
