Way to listen to 26 multicast audio streams?
I need the ability to pipe 26 live multicast audio streams and allow users to listen to them from their phones either via a service on the phone or by dialing a number.
I was thinking what if I just took some audio hardware like usb/firewire based audio interfaces with a total of 26 interfaces, then used IP multicast audio streaming software to generate the streams.
Can I just them write an IP phone service to allow the user to select a stream and listen to it? Or is the format most IP Multicast audio streaming packages generate not the same as to what the phone natively listens to?
1 REPLY
Re: Way to listen to 26 multicast audio streams?
If you have G.711 RTP stream going out over multicast, then just use the RTPMRx: command for the phone to make it listen correctly:
You gotta read this though to really do what you want to do right
http://www.cisco.com/univercd/cc/td/doc/product/voice/vpdd/cdd/3_1/ipphsrvs.htm
126
