05-30-2001 05:55 AM - edited 03-12-2019 11:37 AM
Every Few weeks the Unity Administration Page becomes unavailable and only stopping and starting the services helps fix this. Is there anything that can be done to prevent this from happening?<br><br>
05-30-2001 07:53 AM
When you say "unavailable" what do you mean? Does it come up with a message indicating there are no sessions available or the link doesn't resolve properly or what?
which services are you restarting? Unity's or the WWW/IIS services?
Jeff Lindborg
Unity Product Architect/Answer Monkey
Cisco Systems
lindborg@cisco.com
http://www.AnswerMonkey.net (new page for Unity support tools and scripts)
05-30-2001 08:50 AM
Unfortunately, I can't pinpoint a service for you... I restarted all services you mentioned which fixed the issue. It could be Unity or IIS, I guess... Have you seen this before?
05-30-2001 09:43 AM
I've seen folks temporarily run out of sessions before (since the session stays alive for 20 minutes by default), but you'll get a message indicating that when you attempt to log into the SA. It would really help if you could be more specific about what error you're actually seeing when you try to connect and it fails.
Jeff Lindborg
Cisco Systems
lindborg@cisco.com
