Web Attendant
is it possible in the Web attendant that the user du not see the list with all users in the web attendant window or that the admin can say which numbers he see. We need this at a customer wit different locales.
The other question is, if it is poosible to block the settings button in the web attendant user frontend so that the user cannot change any settings.
Achim
1 REPLY
Re: Web Attendant
These are untested ideas that may or may not work: as it makes modifications to the CISCO asp elements, it will not be supported by CISCO.
Blocking the Settings button, should be as easy as modifying the ASP code that services that page not to show that object. This will impact EVERYONE that uses the page unless you make some special additons to the ASP code.
As far as limiting what numbers are displayed, you could again modify the asp code to prompt first for a location, then popuate based on the location selected. (again you have to modifty some SQL, Javascript, and VBscript to accomplish something like this)
Remember, these are just ideas, not actuall implemented or tested solutions.
94
