WebAttendant Problem
When trying to log in I get the error: "Login Failed: Phone device was found. However the device is not ready". The only can get it to work again is to unplug the phone and reboot the CallManagers. This is a big problem since I can't be doing this in the middle when it happens. Has anyone run into this problem or is it just me?
  • Other Collaboration Voice and Video Subjects
Re: WebAttendant Problem
I ran into this after upgrading a customer from 3.09 to 3.1(2). Call TAC and ask for the updated SAC.DLL that resolves this issue. Good luck.
If you are getting an error that says that "Login Failed:Phone Devices was found. However the device is not ready"
Go to Start -->Programs -->DC Directory dminitrator -->login
Check that the DeviceAuthorithzationRequired field is set to false for CtiFw profile in the DCD setting.The flag should be automatically set for CtiFw when you do the DCD install/upgrade to 3.1
sac.dll is actually for a different issue :
CSCdv21885 : WA User Directory Area Query causes dialing the User DN
-Amisha
Cisco Systems
Just checked and it's already set to false. Any other ideas?
Bronze
I faced this problem once. But once i restarted the TCD service. It worked fine.
DDTS : CSCdu36040
Go to DC Directory Administrator --> Open ctifw-CCNProfile and modify Control Devices...Add the name of the pilot point, and the MAC address of the attendant phone. Stop CCM, CTI, and TCD services on both publisher and subscriber. Restart the CCM, CTI, and TCD services on both machines, restart the WebAttendant and log in.
-Amisha
Cisco systems
You also need to make sure that the phone is not using Multi-Line appearances with the SAME directory number. This is a limitation of the Webattendant that isn't going to be fixed until 1st quarter 2003.
IE:
Line 1 2000
Line 2 2000
Line 3 2000
103
