Community Member
Webdialer - Dial from a webpage (other than directory.asp)
Has anyone created something to make this work? Was it difficult? Are there any 3rd party apps that work good?
Community Member
Re: Webdialer - Dial from a webpage (other than directory.asp)
you can try to call this URL:
https://CMAddress/webdialer/Webdialer?destination=XXXX
with :
CMAddress = Webdialer IP @
XXXX = Number to dial
You can integrate this url as a link under your enterprise directory.
After call the URL you need to log on (user associated to the device) and chose the line to dial
Please rate this Post
Hope it helps
Remy (France)
Community Member
Thanks! I will try it.
154
