well known CCM Registry entries, which ones are they ?
What are the well known registry settings that would allow me to install The CCM.
I have already built a Win 2K server but after i click the installer it decompresses and then tells me to use the cisco approved method. My hunch is that if i hack the registry settings as you suggest it will work.
Therefore can someone tell me the REGI settings. Thanks in advance
1 REPLY
Re: well known CCM Registry entries, which ones are they ?
It is not that simple. You really should use the proper media for your ccm install.
180
