Community Member
What combination of VCware, IOS for IVR?
I have been running the latest recommended IOS
and VCWare images (12.2(15)T7 + 11.31). Now I would
like to start using the IVR feature which doesn't
work properly in many releases. One particularly
annoying problem is that the TCL equality operand
doesn't work for more than 4 digits. I have been
using this as a test:
if { $ani == "6177654321" } {
puts "\n\nRamon is calling from home\n"
} elseif { $ani == "6171234567" } { puts "\n\nramon cell is calling\n"
} else { puts "\n\nSomebody else is calling\n"
it turns out that only the length of the string
and the first character are inspected by the
TCL interpreter to determine equality.
Anyway: what would be a good, reliable combination
of IOS and VCWare for an AS-5300?
Re: What combination of VCware, IOS for IVR?
I think there is some issues with the 12.2(15)T7 + 11.31. Check for 12.2(19) and I think it will not have any problem.
Community Member
I'm using for own IVR application an IOS 12.2(2)XB10 with vcware 7.44 and work fine but I don't know if it the best. I try to use with AS5300 an IOS 12.2(15)T8 but I get a lot of problem with play prompts. If someone know other IOS that work fine please post here.
