What is the difference between gw-accounting h323 and gw-accounting voip commands?
What is the difference between:
1 REPLY
Anonymous
N/A
Re: What is the difference between gw-accounting h323 and gw-acc
"gw-accounting h323" is used to enable gateway specific accounting and the h323 snytax says "H.323 method uses RADIUS to output accounting CDRs." however gw-accounting voip is a new option for both h323 & SIP i.e. "This new option uses RADIUS to output accounting call data records (CDRs). Both H.323 and SIP protocols can use this method, so the name is not bound to a protocol. Use this method with the SIP feature." The gw-accounting is mainly used for SIP accounting but also supports h323.
152
