Community Member
What is the difference between the FXS and FXO voice cards?
I have just inherited a network which contains a small group of sites using VoIP. They are using Cisco 1750s with the VIC cards and Frame Relay. Some of the routers contain the FXS VIC cards and some contain the FXO cards. The documentation I have found explaining the differences is unclear to me so I would appreciate a detailed explanation of when you would use each.
Re: What is the difference between the FXS and FXO voice cards?
There's not much to explain except
1. FXS cards in a vic slot in cisco router represent an analog telephone line
rj11 jack/socket, like pacbell, at&t or BT terminates at your house. You can plug a telephone direct to it
and whenever you pick up your phone itgenerates a dialtone to prompt you todigit collection readiness. It also gerates a ring voltage that ring you phone to alert
you of an incoming calls.
The number assigned to it can be configured on the router as explained in the url.
2. FXO port in the other hand are used to simulate a phone at a PSTN/PBX fxs line termination. The router can make calls out this port to
the pstn/pbx via the fxo port. When a number is dialed say a PSTN number and the proper configuration is inplace to route pstn calls out the fxo port.
The port goes off-hook and get a dial-tone from the pstn/PBX, it then pulse out the dialed digit from an FXS analog phone or contained int the
h225 call set received over ip.
The FXO only connect to PSTN/PBX fxs port. It does not generated dialtone itself and can't plug a phone to it.
